spotted a nice black 33 gtr with standard yellow number plate near macqaurie uni yesterday... (around 7-8pm)... only the second time i've ever seen a black 33gtr other than my old car and KINGTR (or GTRKIN around parramatta area)
spotted white r33 YAE *** this morning on pacific highway at st leonards.
I waved from the s1 white 33 stocker.
I spotted u(ATD 37R) few times on pacific highway but u r early today... bcos i normaly see u on the way back to chatswood.. after drop off my gf at Mater Hospital at Wollstncraft.
did I wave back? I remember I was trying but need to shift gear :wavey:
I like ur muffler sound.. what r they?? once u were boosting out..... and it sounds great :wassup:
SAWAKITA: Were you going down Beecroft road (to Epping) at approximately 7.30PM today (Friday)?
Saw it was a white R33 with GTR wing and bright HIDs so I'm thinking it's you?
yeah that might be me
went to Epping hotel to play pokies with gf
and won some more money for petrol hehehe... :headbang:
Spotted SAWAKITA heading west on Fullers Rd at the speed camera at about noon. Spotted a white R33 GTR [GTR007] on Woodville Rd Guildford at 6pm.
Strange.. I was there but I didn't notice any skyline at that time
U must be driving something else :wavey:
no i was out at the veranda of my gf's house (Regis tower)... ur car looks so damn fine from 17th floor :P its like an rc car..
17th floor ???? how da hell did you know it was my car ?
have you seen my car before ? or was it just a good educated guess ? :D
OI !! you saying my car looks like a toy ???
hahaha
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
