yep BP lights
i only realised it was you after you took off
LMAO the bogan mobile run your car your jk arent you
its a 5L and it still doesnt move i cant wait to get rid of it and get back into my car
hahaha.. i just wanted a run!!! with anyone!!! and you were at those lights.. and you looked like the kind of person who would do a quick run ;) the holden behind me backed off pretty quick.. i was hoping he'd turn off onto kissing pt rd with me!!!! haha.. so that was you with longish hair then!?!??! :(
they are almost my plates i think., but my car is dark blue with a silver front bar.??
I saw the R32 coming out of M2 like a bullet onto Epping Road (heading to city)...took me awhile to catch up!
Also waved/flashed at Sawakita today on Balaclava road - dunno if you recognized me.
i have the car here
im just sorting out all the interior wiring and finishing off the stereo
then its gotta go to the workshop and get all the running gear fitted and all the suspension sorted out and tightened up engine bay detailed wiring hidden etc etc.
then after the SAU show its comming off the road again for some more changes for final battle :cheers:
alright here goes.
last night Spotted Burgundy r33 - zhk-14* about 815 in hornsby and again today at Asquith.
Also last night was a white 33 with black rims at around 930 going past hornsby rsl. Then spotted a r32 on the highway at Waitara (got a wave, can't remember if I waved, sorry if I didn't) which was followed by a 300zx with an SAU sticker.
Around midnight a white 32 with a side mount yellow plate in Berowra.
That is all.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
