Spotted "R34" a few days ago, isnt that manu's car? It was on beachamp road cross anzac pde. Was in my corolla hehe...
yup that was me ....must be on sat around 3-4 pm..i am always there around 3pm coz i work on sat for my bro shop...his shop is there at the intersection of anzac and beauchamp road..
Some absolute wanker in a silver r32 tonight leaving spaceo in lane cove, was coming out behind me, cut across 2 lanes and floored it, mind you i was indicating to merge right, so lucky i didn't. Tis people like him who give skyline drivers a bad reputation :P, apart from that spotted a white r33 in the city on crown street, and a silver r34 on william street round 545pm today.
Danny ie JDM 32R on parra rd just after stanmore maccas...
I was coming out of the city....
I see you finally got ya car back........ :)
lol cool
i saw you too last night at bella carwahs :P
and IKEA hehehe
sorrhy about the shit organisation
Saw a silver 34, 18" wheels(wire spoke wheels), no wing and a large skylinesaustralia dot com sticker on the back window. I was up in wentworth in the blue mountains staring at you as you drove past, i was getting into the commodore as my car is still in melbourne, i am on holiday here in syd.
R34 GTT UN33EK castle street towers bound
That car parks two houses up from me everyday at my home. I have no idea whether they are on SAU or not, would love to know if they are... nice looking car hey! :O I never see the owner.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
