spotted midnight purple R33 GTR at Moorepark golf QLD plate, looks stock and very clean. Also spotted TRD33Y on Liverpool Rd infront of Shark Hotel tonite 12ish
where u in that black 33 s2?
Hey Slim, I saw your car parked at Maccas today with a heap of other skylines and Type Rs
I remember your plate from this forum, just saying hi.
Funnily enough my friend has a type R, we were heading up towards the F3 and had brekky at Maccas
Yeah we had a cruise today to the gong, then back thru macquarie pass :P
I think I saw you, you drove past my car then straight out onto the rd.. I was standing next to the building hiding in the shade
Spotted Revit ( sam I think ? ) onnn windsor rd or old windsor rd
and spotted BWA. somewhere.. cant remember where
im too sunburnt and tired form the cruise toay to think
I saw you on the hume highway on the way back from Wils :D I thought none of you saw me lol
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
