Had a bit of a run through northbridge last night with a black R32 GT-R.. not sure if they are on here though.. didn't catch the number plate.. was too busy.. driving..
also spotted - a new tattoo heading over to manly a week ago or so.. didn't realise until she'd already passed..
Spotted a white R33 S2 blowing away someone at the lights on Lane Cove road near Macquarie. Tossed out a wave..got one back.
Am i too hungover today to go to the autosalon? ..i think so
spotted KEL looking all sexy at the amex chrissie party last night!!!! :)  didn't see you again after that! hope you got suitably smashed!!!!!!!! :)
This is a CAR spotting thread...not a PEOPLE spotting thread....
mods please remove :)
hehehe
lol spotting people.
I spotted heaps of skylines around paramatta road today. A few silver ones.. And spotted JEF33R :) Well he spotted me and said hi :)
Lucky you found nice parking outside autosalon main enterance.!
spotted a silver R34 Gt on the old pac today
then a maroon 33 GTSt on edgeworthdavid ave - hornsby - got a wave
and a P plater on a black R34 GT near St Ives
and morgs's car everyday :)
Saw a black R32 on the F3 today :) Waves and laughs. (Daddy was testing out the R33).
Saw a white R33 Series 2 at some traffic lights, took off like hell.
Spotted a Marone R33 out of the corner of my eye but didn't get a chance to wave.
Also a little Toyota Starlet with a turbo outside of mass_iv's house in West Ryde.
You were looking pretty good yourself Moanie!
The night ended with me suitably trashed- hope you had a good one too!
Spotted lots of Skylines in the carparks around Autosalon today.
You definitely didn't need to go inside for a show!
I saw a car which look exactly like wils on the front but then when it when passed me I saw it had a F&F sticker (cyclops angel thing pointing forward) and a bunch of Leb guys inside :P
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
