spotted a Black 32 with black plates in west ryde
black 32 at a round about near macquarie shopping center.
another black 32 near top ryde
redish 33 parked at bunnings
farken heaps of black 32's out there
spotted a silver 34 stuck in traffic... city bound on epping road at about 6:30... i said hi... lol!!!!  but i don't think you would have heard it! :D
omg. I can actually picture you screaming "hi!!!!!!!!!" out the window at some random line hahahah
Saw u this morning Wink..bout 6:30 castle hill rd.
How'd you go getting your car tuned at MRC last week?
Oh cool, I was heading to work.
Results were good from the tune. 185rwkw but now I need a SAFC to help with AFRs.
