heheh thats k I was turn and wave but was too scared that the guy in front of me might suddenly stop!
LOL it gets like that on the Anzac Bridge! I have a theory that *most* of the world's crap drivers run over it each day!
I spotted a white R32 with a black or carbon bonnet this afternoon @ around 3pm (wasn't paying attention to the time) on Seven Hills Road heading away from Baulko, it was near the school and where that field/skate park is. Didn't catch the plates, but I did give a quick flash of the high-beams.
I was in the Stagea and heading towards Baulko to get some last-minute pressies (came away emty-handed, oh well...)
cool i got spootted yeah!!
what car were u in..
i remeber being highbeamed by a non skyline..
i thought it was a cop warning..
pfft zeds........350z...yeah I rate them......
but 300zx...meh.....I dont wanna be flamed by some of the zed lovers....so ill keep my comments to myself.
hahaha! good call... these peeps don't mess around :lol: :lol: :lol:
veery passionate!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
