been spotting heaps of skylines in nwecastle/maitland area, a nice yellow R34 GTT today outside the model shop, a banged up black R33 from lochenvar to maitland and other assorted makes and models throughout the city.
Spotted my twin the other day- white r32 gtst with white multispoke rims and even had the same number plate AWL but had red Ps instead of green. It was in campbelltown. Also saw a chick driving a black R34 about 30 mins later.
yeah it was the exact same car as me :D
like if i wasnt in my car and i saw it driving i would think someone stole my car because the only difference was the last 2 numbers and letter on the number plate
That's bizarre. Fancy the same plate coming out of the registry (close to where your car was initially registered) AND given to some other skyline, which happens to be white, which is owned by a p plater.
*boggle*
Spotted SNG ... this car f**king owns - 32 GTR.
i been seeing it around the car yards on the great western highway near kingswood station.
the green STAGEA,havent heard or seen it go yet,but it looks the part.
Speaking of your number plate.. Last nite on the cops, officer did a check on a car and firstly they said the plate was "RSTME" and it came up with a skyline maroan in colour, but the car was a they stopped was a wrx.. a few mins later, confused officer goes oh I think the number plate is "R5TME". :D
So anyways you own a maroan skyline?
saw MAR55S and the previous owner of my car (now has gtr) in the fox studios car park, last night at around 8pm.
also saw a brand new f430 convertible start up and hoon out of there that was nice :P
Edited by siksII
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
