On the 26th, spotted a few black R33's on the way down to Nowra around albion park... One gave me a wave :P
On the 27th you would have seen a Green R33 as well. Pity... :P
Saw a Maroon R33 SII heading North through Nowra today 28/12. Veeeerrrry shiny. New paint job ?
Anyone ?
El Bee
saw MAR55S and the previous owner of my car (now has gtr) in the fox studios car park, last night at around 8pm.
also saw a brand new f430 convertible start up and hoon out of there that was nice :huh:
Was that your S2 there.. about 20 meters from where mine was???
I almost parked next to it to take a pic... then i thought.... nah... too wanky
:wavey:
That's bizarre. Fancy the same plate coming out of the registry (close to where your car was initially registered) AND given to some other skyline, which happens to be white, which is owned by a p plater.
*boggle*
Spotted SNG ... this car f**king owns - 32 GTR.
Wow, 3 years of owning a skyline and finally been spotted, i must blend in well. :huh: When was this and what were u driving?
Wow, 3 years of owning a skyline and finally been spotted, i must blend in well.  :(  When was this and what were u driving?
That's twice I've spotted you man! A few pages back I spotted you at the mechanics!. Your car was on the hoist when I dropped my car off.
28th of Dec I spotted you going past crown of the hill (theos liquor) right after the Roseville Bridge. Was driving my white family car. If you're around north shore/northern beaches area and goin for a cruise lemme know .. Love to see that car on the road again :huh:
On the 27th you would have seen a Green R33 as well. Pity...  :(
Anyone ?
El Bee
Sorry mate, was kneeboarding that day :huh: Back home now, and didnt see any other lines coming home yesterday afternoon...
haha dude I saw your car pretty much the first week I got my car....
At the sau dyno day at croydon.......
your friend or brother has a silver 33 with CNG plates right?
hahaha just out of curiosity what does CNG and SNG mean ?
Yeah i was at the dyno day, that was years ago though, can barely remember it. :)
28th of Dec I spotted you going past crown of the hill (theos liquor) right after the Roseville Bridge. Was driving my white family car. If you're around north shore/northern beaches area and goin for a cruise lemme know .. Love to see that car on the road again :)
Yep, im out all over the place which is suprising i havent been spotted before, i'll keep an eye out for you next time. You live near the Roseville Bridge area do you? I guess i'll probably be spotted more often now you've seen the car. :D
tried,but a 4wd was trying to take my lane around the corner.
did you see the maroon 32?
i seen him go up doonside rd the down holbeche.
also OFD14L a maroon 33 lives near me(are you on here dude?)
also has a silver 33 4door i noticed today.
I didn't see any skylines today :)
I usually see heaps around that area though
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
