hey silver was I parked or cruising around ??
You should have seen slim, and dave and mona, liz as well....
I was at shelbourne for a mates bday.....thent met up with them later.....
mar55s......hehe...I agree with your IMPUL statement in your sig :P
just u, cruising near city hotel
Hahahaha! hey mass.. we were just getting some take away coffee.. then realized it was a parking spot so just stayed there and finished drinking.. saw a black 34 with wot i think was a tommy Kaira kit... very nois..
BTW.. wots that front bar Mass?? I Like. :P
lol dude i get that heaps i dont know exactly as it came with the car, but i havent seen it anywhere... it doesnt have a name on it, i think it may be a custom job, but it looks similar to some of the trust bars
If it was a dark green Stagea, then it was most likely me!
Whereabouts in Parra were you and what time was this?
I think I saw you on Old Northern Rd a couple of days ago.. I was in the White 33 that flashed you going the other way. Either it was you or another green stagea! :P
if anyone saw my car this morning between 1:30 and 7:00 am please call me immediately (0422 646 173)
:) Aww nooo! I hope the bastards who stole it die a painful, horrible death - and burn in hell forever..
Sorry to hear your loss mate ;):P
DJ - where from in Hornsby mate?(understand if you dont want to post it)
il lkeep an eye out
Sorry to hear your loss :D hope the muthafockers rott in hell slowly.
i think I saw Kels black 350.. does it have skylinesaustralia.com sticker across the front window?
LOL- the Zed does have the shticker. It gets lots of funny looks, but we are an owner *and* enthusiasts club right?!
Spotted lots of lines out over the weekend but I'm hopeless at remembering plates. Now I just wave at everyone in case they're an SAU-er :P
ive spotted so many skylines over the weekend.... wasnt in my car though... seen a couple of nice ones down south in the last couple of nights......
dont think any were you regular broad minded persons :P
I think I saw you on Old Northern Rd a couple of days ago.. I was in the White 33 that flashed you going the other way. Either it was you or another green stagea! ;)
Hmmm, Old Northern Road is fairly close to home, but I can't remember when I used it last... Was I heading towards or away from Castle Hill?
:P:P
I swear it wasnt you or duncan driving though. anyone else been driving your car?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
