spotted GTR-26C ... nice car :rofl:
and i *think* it was GTR-32X (the silver r32) who beeped at me while going the opposite way from me around 6.30.. i think it was on windsor road
Yep
that was us
hahaha sam tosh doesnt drive a skyline....
he has never owned one !!! :P
SOOOOOOOOOOFFFFFTT
The mighty MR2 Turbo chopped plenty of Skylines in it's time Thomas :) Even yours around Wakefield ;)
And you tell a lie Thomas, I drive a different Skyline almost everyday... just don't own one :)
Hmmm, Old Northern Road is fairly close to home, but I can't remember when I used it last...  Was I heading towards or away from Castle Hill?
Towards...
between 6:30 and 7:30pm
silver r33 on windsor rd
white r34 on james ruse drive with CF bonnet
wine red R32 ( gtr i think ) on kissing point rd
purple r33 with shopping list stopped next to him at the lights got a nod and then wave as he turned off..loved the colour even though it was a bit dirty haha
:D
hahah tosh you cant compare a modded MR2 to a bone stock gtt around wakie...
give me another month or two to get coilovers and then well see :D
hahah give me a stock gtt and wakefield and we will see about that pesky mr2 muahahahah
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
