spotted one white gts-t with 400r kit outside love machine in kings cross tonight, then another white gts-t series one with p plates on elizabeth street surry hills outside a brothel.
for privacy reasons i wont post the plates, jeez u skyline owners are horny bastards! this is also not the first time ive seen a skyline outside that brothel!
both were at about 1245am.
Edited by siksII
sif.. I live in east subs..
though havent really driven car around much lately.. only to and from work.. down and up anzac pde.
So thats what 2 people? lol.. inc me..
Thats so ghay.. i never see you.. altho im more round mascot/ pagewood.. what skyline you got..
Yesterday arvo saw a white 33 on wentworth ave heading towards mascot at about 5.37pm.. plates where ask*** something like that..
who cares about the plates, just post of the address so we can tell others not to come to these places :wink:
what i want to know is what YOU'RE doing there arup! :cheers:
and spotted a white 33 on the m2 this morning!! i looked over and smiled.. the guy just looked straight ahead! i then blocked him in traffic further enough cause he wasn't quick enough to change lanes! LOL!
Sorry!!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
