Suki or whatever her name is from 2F2F is UGLY++
Havent you heard the saying "any holes a goal." :laugh:
Black. :huh:
Ill look out for your car...
I THINK I REMEBER YOU NOW! I was in the car with my sister maybe about a month ago..
you were driving next to me on bunnergong rd and down wentworth.. ave and then some other noodle in a skyline zoom past and you sped up with him.. maybe it was you.. theres not alot of of black 33's round the area..
I drive a black 32
Havent you heard the saying "any holes a goal." :huh:
I drive a black 32
dunno cant say I remember what happened last nite let alone last month. :laugh:
I forgot the password to my work email :P and only changed it last nite
OK should stop wh0ring in the spotted thread.. seeya!
omg :P with a name like corinne, i thought you were a girl?! :P
omg :) with a name like corinne, i thought you were a girl?! :O
HAHA :laugh:
If that was true
QUOTE(D_I_F @ 2 Mar 2006, 12:58 PM)
yea it is.. shes hot isnt she..
Very nice arse..
You know what the above statment would mean! :huh:
Double post moanie?
Is that a gremlin again or do you need to complain to prank!
i need to complain!! every thread i post (bar the whore thread) it gives me an error but posts.. so i refresh and it posts again!!!
Yes, sure its not a pebcak or an ID-10-T error?
JK :laugh:
Saw it happen in the NSW dyno day topic
sh ms!!!
spotted the below on tuesday evening:
spotted a white 33 on the city westlink about 7pm.. got a wave:D
also spotted another white 33 going the other way on the rd on the other side of parra rd from the city westlink! lol!!! he was heading towards the city.. i think i got a belated beep? :P
(posted it in the wrong spotted thread! LOL!)
Spot a Yellow R34 GTT every morning on the way to work on Lane Cove road heading towards homebush
Spotted a grey 32 GTR on pacific hwy chatswood heading northbound. Threw a wave...got one back
Spoted a silver 350Z taking my car space this morning at Chatswood.
oh! and corinne! check out the chick drag thread in the events section!! DO IT!!!!
i havent been able to post for ages now..
i dont think i would go in one of those.. :S
my cars mostly stock.. i dont have a cams licence.. i would have to do some work on my car before anything like that happened.. i dont even know what speed im going at my speedo is out.. :S
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
