spotted a silver 4 door R32 (enyimports.com.au slicker on back window) near Warringah Mall on Sunday, so I drove next to him to give a wave, both lanes turn right and so we did, then the f**ker merged in to my lane as he went around the corner.
last time I go out of my way to say hello to someone with a similar car.
dopey prick
I spotted that car as well a few days ago down at Dee Why, but I wasnt in my 4 door at the time
Spotted ranicx's car being jacked up to have it's wheels stolen by me and him haha (good on ya man!!)
Had a 'look of recognition' from someone here but didn't have time to wave - if anyone saw me in the cefiro that was prolly you. On Link Rd on Saturday...
Spotted a couple of 34's over the weekend too... One in a Neutral Bay servo looking suspiciously like Adams car :bunny:
woops..
wrong ceffie..
sorry mixed you up with ceffie.. my bad
Yeah that's Nic - thought so hehe
dopey prick
I saw that guy on the weekend too. Totally stock lookin!
how many ppl live on the northern beaches thats on SAU? im always driving around deewhy brooky, rarely see any skylines on the road
