Nice white 34 seen my SAU sticker on my Dato 280Z and gave me a thumbs up on what I think was Manly rd (just before the spit bridge). Nice ride dude.
Was thinking of pulling over and saying hi but the missus wanted to get home to watch some TV show.
I was going to post that I saw you but then I thought, 'was it a 260 or a 280? I don't know.' and then the moment was lost.
Thanks mate but it's pretty dirty since the track day.
You don't know how close I was to owning a 280 a year or so ago. I test drove then was going to get it the following week but blew my turbo on the weekend.
chased an odd looking R32 last night up windsor road
red GTSt stock frton end with fiberglass GTR rear guards and odd looking tail lights
confused the shit out of me for a while
Spotted, some ugly car with 2GU UP plates at Yennora Bunnings on Saturday night.
The owner must have been getting some hardware :D
What did you think of the Ignition meet Anf?
spotted a 32GTR in Asquith yesturday - was that you rb30gtr (Ben??)
Look great!
:teehee: haha just reading back, yeh chris was me, Nice 33 to you, I was driving slow, stupid cop shop....
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
