I just saw a pearl white R34 GTR M Spec drive past the shop in Drummoyne. ATW-### I think???
I drive past there all the time, i'm surpised you haven't seen me before.
She is fillthy dirty , usualy she is spotless.
Spotted: My sorry ass without a sky.
I really miss my 33 gtr :(
I really want another one, but im not sure what to do. I only have 12-15k atm and want something to drive around in. :D But want to save up for another 32/33 gtr
I miss my old car, she is my love (L)
What do people suggest?
my gtr is broken..
get a clean 32 gtst - they work.
I presume a shitbox = 32 or 33 gts-t ?
gtr's are shit
:werd: rukus
spotted mass_iv, Shonen, rukus and Beer Baron today
I had a nightmare like that once to.
Moanie, if you see Kel again can you say Hi from me? and ask how the kids are?
I thought it would have been you... only know of 1 other Pearl White M Spec in Sydney and I know the owner quite well "GTRPWR"
Yeah it was filthy.. haha you should have stopped past the car wash down the road :angry: Looked like quite a nasty exhaust stain up the rear bumper bar too
And yes I have seen you a few times before :O
I know of the other pearl M-Spec , i spoke to the owner a long time ago ( 12months?) at a set of traffic lights if i remember right his name is Omar, as far as i know they are the only 2 M-specs in Sydney.
Its usualy very clean but with all the rain we had, i thought there is no point in washing it.
dhc always gets spotted!
Is it really loud yet?
your just jealous wilbur :angry:
and NO its not arrived yet....f**kers f**ked me around.....they waited until I called them to tell me that they have run out of stock in Japan and they now have to MAKE it.....another month :O
Spotted a white 33 in Buladelah yesterday at about 4.30
I would have looked really strange, coz I was leaning forward pulling up the tounge in my shoe when I spotted you and waved, so I probably looked about 3 feet tall :angry:
Edited by Lazy-Bastard
That's him Omar.
AFAIK there are only 2 as well.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
