spotted JET333 or 33R this arvo - I yelled out to you - I was on that masssive street commodore cruise near heathcote road I think it was?
600plus cars and over 18k for charity
Just spotted TRD-33Y crusing along the Pac Highway at Killara on his way to Alchoholics Anonymous
I was crusing yea too much traffic on pac hwy tonite : , haha sif me goto AA :)
YAY! I got spotted! :)
I didnt see you? I didnt see any lines on pac hwy :D
Spotted two lines at gosford today, some gunmetal 33 with red Ps and a black 32 parked at terrigal.
Spotted a black 32gtst at eastgardens i followed you!
WHO ARE YOUU!! ;)
Stalker!
Spotted 2GU UP in the show and shine @ Eastern creek yesterday for the Drifting..
Spotted about a million other lines and other Jap cars out there as well.. waay too many to spot! :)
