Lets see..
Spotted xizor at livo kk's haha..
spotted a yellow 34 gtt plates flyr34 soemthing like that at livo kk's was about to go up and talked to you but you walked off into the shops
Spotted a white 34 gtt at moorebank ave glenfield.. 9.26ish
And saw a black 33 get off the m5 the turn off after glenfield heading towards the city.. 9.30ish and i got my first wave! omgosh so exciting.. i waved back.. hellooo to whoever you are!
:happy:
spotted grey r32 4 door on Alison rd/ Dacey ave tonite. was in a white 2 door r32.
they were in a white 32 corrine! do you have white rims on your 32 and yellow plates? if so i see you all the time, city everywhere!!!!!!
ive seen that 4door too,, RBH.00N i think, nice plate :P
That might have been mr_ed32 what colour is youre 32? and are you around the eastern subs?
im the only official whitie :P
hahahahah combi's!!
All the below last night...
Saw a hot blue R33 in ctown last night just before 6pm.
Saw a black R34 on hume highway heading towards casula from liverpool about 6pm.
Saw yellow R34 that corinne mentioned above at orange groave rd KK carpark.
Saw black S1 R33 at KK carpark, RBFIRE from the forum, cos i had to meet him to sell something.
And lastly saw Corinne's R33 parked next to mine at same KK carpark last night. w00t :)
spotted a big bunch of VW Combi's all in a line following each other on Newline Rd this morning.
Should we be worried?
I have a feeling there's gonna be a mass-suicide happening today....
There's a VW meet on this weekend at Nambucca Heads on the north coast - no doubt they were all heading up there...very slowly :)
There's a VW meet on this weekend at Nambucca Heads on the north coast - no doubt they were all heading up there...very slowly :D
i was about to say the same thing.....
slowly but surely :)
Hmmm, they should've let earlier then. At this rate they'll be there by Monday. :woot:
spotted dark green or blue 33 with chromies at the end of the F3 friday morning.
also spotted white 33 on pacific hwy wahroongah about 5 mins after that, think i got a wave back but not sure?!?.
Hmmm, they should've let earlier then. At this rate they'll be there by Monday. :)
My best mate headed up there today too, he goes almost every event and has asked me numerous times to come along. He's driving his friend's car up, his wife is in tow with their sons in their 01 WRX, and the friend (who works for Subaru) is driving a current STi up, just to keep the whole flat-four theme going. I really should go next time, would be a good chance to get away from Sydney.
Back on topic, I saw a gunmetal R32 today in Toongabbie and followed it along Fitzwilliam Rd and over the bridge before we turned opposite ways. Plates were "R32" and it had some "questionable" chromies on the front, and stocky GTSt wheels on the back... Definitely not to my taste.
spotted, wine red r32 with r34 gtr rims dumped on its balls in cronulla
2 silver r33s in cronulla, a white one parked in a servo,
a silver gtr drivin around
and more but cant remember...
so many skylines in cronulla, they are like taxis!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
