i saw a banana boat going past homebush on saturday (on that main road you know the one, nor parra road, the one that crosses it!).. was that you??
yeah that was me.. I SAW YOU TOO!
Yea 2835's, fairly sure its black, its a long time ago that i saw it @WSID, he had problems with boost that time only ran 12's i think .
How is your engine build going? Did you see the white stock 33 GTR in HPI mag ? Do you recognize it?
Have you seen it Mona? How is the new donk going? Finished yet?
Its a white series III, looks pretty stock under the bonnet ..... You may remember it Charlie at UAS a few months ago.
Edited by wrxhoon
nah i haven't.. just heard about it :) need to stop in at a newsagent to get a copy :(
and nooo.. not finished yet.. another 2 months maybe :P
spotted SMASHAAAA in epping tonight...the last SAUer to ever see my car :( with me behind the wheel anyway
so long ya big white whale! :P
I don't know if yo saw, but I gave you a delayed wave :)
sad to see her go, Liz.
Won't know what to look out for any more :laugh:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
