hahahaah so that was YOU !!!
I was swearing my head off to my mate in the car when you did that
hehehe...its all good...
Im lucky it was raining otherwise I would have yelled out at you...hahaha which would have been embarrassing if you spotted me after that :P
Haha the irony is I crossed the road just to check the car out closer. Why were you stressing was it my umbrella close to your car? If so sorry - I was very conscious of not touching the paint, it was immac - just wanted to get a closer look :(
spotted primordial 2 cars in front of me heading down Coonara Ave this morning.
Were you trying to wave at me with your rear wiper? :( hehehehe
I didnt notice you back there!
Haha.. I was trying to clear my back windscreen but the wiper blade is about as effective as using one of Bob Marleys dreadlocks!! :P
Changing the rear windscreen wiper is one of those jobs you never get around to on your car...
Haha the irony is I crossed the road just to check the car out closer. Why were you stressing was it my umbrella close to your car? If so sorry - I was very conscious of not touching the paint, it was immac - just wanted to get a closer look :dry:
if you think it was immaculate then you did need a closer look :(
if you think it was immaculate then you did need a closer look :D
haha yeah sams right..
My paint is FUUCKED....
keyed 9 times and the front bar has so many stone chips my mate refers to it as the "new look galaxy paint job"
hahahah and nah I didnt even notice your umbrella you just jumped out in front from nowhere...was a bit unexpected thats all hahahaha :kiss:
hahahah and nah I didnt even notice your umbrella you just jumped out in front from nowhere...was a bit unexpected thats all hahahaha ;)
ahh - heheheI only crossed the street when you were waiting at the lights and were waiting there till I had crossed another street. So yeah if someone jumped out in front of you that day it wasn't me.
Ahhh whatever.. Nice car :P
hahaha yeh thanks, she bought it bout 3 weeks ago... i saw u wen i was in it not long ago, i think last week, on the hume highway, i was heading towards liverpool u were going the otherway, i tried to get ur attention but u didnt realise it was me, coz of the supra lol....
hows the car man?
cars going great.... im gna sell it n buy a boat :P im loosing my license..
u know neone selln a boat dude ;) lol
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
