hahahaah so that was YOU !!!
I was swearing my head off to my mate in the car when you did that
hehehe...its all good...
Im lucky it was raining otherwise I would have yelled out at you...hahaha which would have been embarrassing if you spotted me after that :P
Haha the irony is I crossed the road just to check the car out closer. Why were you stressing was it my umbrella close to your car? If so sorry - I was very conscious of not touching the paint, it was immac - just wanted to get a closer look :(
spotted primordial 2 cars in front of me heading down Coonara Ave this morning.
Were you trying to wave at me with your rear wiper? :( hehehehe
I didnt notice you back there!
Haha.. I was trying to clear my back windscreen but the wiper blade is about as effective as using one of Bob Marleys dreadlocks!! :P
Changing the rear windscreen wiper is one of those jobs you never get around to on your car...
Haha the irony is I crossed the road just to check the car out closer. Why were you stressing was it my umbrella close to your car? If so sorry - I was very conscious of not touching the paint, it was immac - just wanted to get a closer look :dry:
if you think it was immaculate then you did need a closer look :(
if you think it was immaculate then you did need a closer look :D
haha yeah sams right..
My paint is FUUCKED....
keyed 9 times and the front bar has so many stone chips my mate refers to it as the "new look galaxy paint job"
hahahah and nah I didnt even notice your umbrella you just jumped out in front from nowhere...was a bit unexpected thats all hahahaha :kiss:
hahahah and nah I didnt even notice your umbrella you just jumped out in front from nowhere...was a bit unexpected thats all hahahaha ;)
ahh - heheheI only crossed the street when you were waiting at the lights and were waiting there till I had crossed another street. So yeah if someone jumped out in front of you that day it wasn't me.
Ahhh whatever.. Nice car :P
hahaha yeh thanks, she bought it bout 3 weeks ago... i saw u wen i was in it not long ago, i think last week, on the hume highway, i was heading towards liverpool u were going the otherway, i tried to get ur attention but u didnt realise it was me, coz of the supra lol....
hows the car man?
cars going great.... im gna sell it n buy a boat :P im loosing my license..
u know neone selln a boat dude ;) lol
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
