Spotted Ferrari 430 in chatwood but the little dead end lane......some bald guy was driving it and tried to impress the ladies by revving it on his way out. Sadly all he got was a couple of disgusted head shakes, no one was impressed
ok just spotted a dude in a blue r34 GTR with green p plates, on hume highway, the was also a wrx they dragged and i sat back and watched not far behind, wen i decided to give it a hit the gtr turned off :laugh:
but by the looks of it, the wrx kept up with him :D
so i raced the rexy and um hate to say it, i left him for dead :D
also spotted a pulsar sss, with an sr20det in it, man that thing went hard, gave him a run also and only managed to pull away slowly in 4th gear :( it had some grunt!!!
Edited by mass_iv
spotted a white r34 gtr GTR PWR had a lil run with him on silverwater rd
HOLY F*$&%EN SHIT!!! He actually took it out and drove it!!! hahahaha
Spotted Mass just then trying to look hektik in his Skyline on Victoria Rd :P
Spotted Mass just then trying to look hektik in his Skyline on Victoria Rd :(
hahaha sif trying look hektik :( I AM HEKTIK ;)
Spotted me and mass outside the shop in rushcutters tonight....
i was eating some of that fffffffffarken awesome gelato he has to offer! Highly Recommended!!!!!!!!!!!!
hehehe yep that gelato has attracted some of the whores already in the past :ban:
ah the good old gelato runs.....
now on another note, i just got pulled over on my way home from work :ban:
i was speeding over that dam old anzac bridge, i copped a $590 fine and am going to lose my licence again for 3 months :ban: this is just not my month!!! stupid 60 zone, shud be 80 :P
now on another note, i just got pulled over on my way home from work :(
i was speeding over that dam old anzac bridge, i copped a $590 fine and am going to lose my licence again for 3 months :( this is just not my month!!! stupid 60 zone, shud be 80 :P
ghey
thats MY gelato!!! :D
hahaha sif trying look hektik :O I AM HEKTIK :pirate:
hehehe yep that gelato has attracted some of the whores already in the past :pirate:
now on another note, i just got pulled over on my way home from work :rofl:
i was speeding over that dam old anzac bridge, i copped a $590 fine and am going to lose my licence again for 3 months :( this is just not my month!!! stupid 60 zone, shud be 80 :thumbsup:
oh -MASS- :(
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
