spotted a hot lookin maroon r32 with no wing at erina today. gave him a flash but no reply.
spotted gunmetal r33 somewhere in gosford....cant really remember where???. flashed him tho, no reply
spotted a white r33 with a wicked front spoiler, flashed but was going to fast to see if i got a reply.... :sick:(
does nobody wanna wave to me??...oh why...oh why???.
ooo!!! forgot to mention i saw a s2 silvler r33 parked in the amex carpark on liverpool st... i swear you had a sau sticker on the back!!! plates were AZA something... :D
haha, that was me. I work in the amex building, parkings a bit pricey there though so I don’t drive in that often.
Also, saw UPB33T.. R33 GTST a few times this week.
I always see a white R33 VSpec parked outside near a bus stop, near a roundabout.. Sorry i cant give that gooda information, im trying to think how i can explain it better. All i know is that a street closeish to it is called 'The Bastion'. I see it almost everyday on the bus after school.. looks, clean, and saw the owners driving it up past the Blue Gum at Waitara this week. Anyone know it?
Spotted a hottie in a purple 32 in St Clair today,
Also spotted a guy in St Clair driving a black 180 get sideways in the wet mount the gutter and end up in someones front lawn before hitting a tree, hope the driver was ok.
spotted a white 34 on pennet hills rd this morning i think the plate was cmefly it also had a black bonnet. the car looked so hot
CYIFLY - I love that car.
I spotted about 20 lines last night on Heathcote road, all in a row.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
