spotted liz in the siliva going for a run down the old pac yesterday. i think it was u cos they beep when i was at the truck stop.
sure was!!!!!!
Christmas Cruise..
bummer, I missed out!
ps. your car looks nice dude, we saw it parked on the side of the road!
enrique! You should really stop stalking me you know!
sure was!!!!!!
lol, i saw your silvia, looks clean :(
was i near the car when you drove past?
bloody hell I spotted 41 skylines at Fagan park. was something on?
Bunch of bloody hoons, they are, these Skyline drivers...
Get a Volvo!
(A Nissan "Volvo," that is!) :(
LOTI!!!!!!!!!!!!!!!!!!!!!!!
hahahahaha
LOTI always results in a LOL
lol, i saw your silvia, looks clean :D
cheers! I :P it. hahah clean apart from all the unburnt fuel on the rear bar. Please no one smoke near my car lol.
nah you weren't!! It was just parked out front
Spotted Corinne (D_I_F) on old northern today, she pulled over and lent me a hand... Thanks for that... Love that car :thanks:.. have fun for the rest of your cruise :P
OMG! Ive finally been spotted!!!!!!! NO WAY! haha..
Lucky you were alright :D
Cool. Few people know that I actually grew up ON Fagan Park. My old man was the caretaker. Ahhh, the memories of having a 140acre backyard and a trail bike. Noice
Hahahaha! FAGan Park.
i wouldn't tell many people either
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
