spotted a black 33 on the old pac highway about 6pm last night... i flashed my lights... then wondered why you jammed on the brakes lol.
i was in a white ss.... ex cop car style lol. sorry for scaring you! lol.
was the number plates upb33t
spotted trublsm at Dural Maccas. :)
didn't wave cause there was a large group of ppl and didn't really want to wave to a group of large ppl that we didn't know. lol
Plus didn't see you wave...
lol wilch, i was like... wait a second i know that white r32 with the number 6 on it!
hehe i saw yas, then was like ooh should i go say hi but i was with my mates so...
i waved as you guys drove out, waved to amanda lol.. she didn't wave back :huh:
Spotted a black 33 going down Heathcote rd around 5pm today and a Silver s2 r33 turning off the m5 motorway onto the M7 this afternoon at around 6pm (he was behind me for a good few k's)
upd33t isny a meneber here
Liz - SS commods ftw!!!!!!!!!!!!!!
Oh, I spotted a black 32GTR in hornsby - it was in a parents with prams parking spot...and it had p plates..........hope you had a pran.....
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
