I was the gunmetal grey R33 GTST.. I stuck my head out the window as I turned into the motorway :nyaanyaa:
did u wave to me i have a black 32 with black rims? if not i spotted a gunmetal grey 33 last night he waved i waved
Hahahaha!! :nyaanyaa: whoops!! :D:P
Damn you Smoky *shakes fist* .......... hahahahahahahaha
I had NO idea where I was and was just following stove lights!!! I thought everyone had gone down towards the bridge or something and I was going god knows where!!!
Yep that would have been me :/
Hahahaha!! :wub: sorry Kasey :wub:
spotted a white 33 at Wils fav roundaout in cherrybrook this morning.. at about 7:45am.. also spotted at about 8:30, a silver s2 33 with impuls at the bathurst st/anzac bridge intersection!
:wub:
That was me Mooner :wub:
didn't see you tho
There is a nice midnight blue 32 GTR in Blaxland Lower Blue Mountains....I see the car all the time and would love to chat with the owner....anyone know this car or owner ???
Spotted a white R34 GTT (not sure of where I was) they waved and I think I saw a SAU sticker.
I was in passenger seat of my car :D So dad didn't wave but I did.
Also spotted a black R33 GTST with clear tail lights, nismo stickers and an enlarged skyline "S" above the GT badges. Waved but no look
really?! ms said it was you, then took it back! :huh: what are your plates? SQ11SH? or something?:) we were just coming off anzac bridge and heading up bathurst st... you cross in front of us :P
Yea...
Them's my plates :P
Didn't see you guys... :wave:
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
