Was that you, Thomas?
Didn't recognise you either, because I only got a proper chance to look at you in the rear-view mirror, and I figured it would be a better idea to keep an eye on the road - especially through those curvy bits leading up to Ermington...
Heard a small chirp as you left the lights in front of me just before you turned onto Silverwater Rd. Button clutch?
pffft button clutch...I wish. ;)
Try nismo triple plate.....that thing is officially the most bastard of a clutch I have ever driven with.
Spotted Ethan again on Wed night
spoted you too! sorry about the late wave
spoted and waved to a few other people today, but cant remember them all.
also saw will and girl (sorry ive had a mental blank.. dont kill me), at the towers today when i was looking for a park.
lol
Hey dude ;)
"Amanda" :(
We waited for you around the corner for a bit. Thought you might've wanted our spot.
lol
Hey dude :/
"Amanda" :)
ohh, i dont think i actualy saw your car at all.. i a white gtt but thats all.. ended up parking outside
spotted a few lines at thornleigh maccas last nite. mike, mitch and another sau guy but cant remeber ur name sorry mate
spotted the same.if think is user name started with s
I was parked next to a nice 33 series 2 GTST @ Newport beach today, plates were KRUZN... nice ride !
Also saw a few GTRs going up the mountains through Blaxland today as I was leavin for the beach....they were with a huge group of RX7s and rotories on a mountains tour... :P:)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
