Spotted Liz at Hornsby RTA bout 15 mins ago :yes:
hi5!
how funny was the guy who served us hahaha..
he was trying to make be burst out laughing for the photo, so I pulled a face instead and he snapped it! It took me 10mins to convince him to do it again! lol
Hey dude do you drive a White NA 34 with red P plates and your in St Clair fairly often? if so ive spotted you a fair bit in St Clair.
haha yer bro. always dropping mates off n shit. i live in st.clair.
i think ive spotted u a fair few times aswell man.
theres 3 black r32 skylines ive spotted in st.clair a few times
Edited by peshays
Spotted a silver R33 on the way to RTA in richmond thismorning
and a silver r34 4 door in epping with skylinesaustralia.com sticker on the front of the car
Umm.. the R34 4 door in epping would of been me. What were you in??
Just put my sticker on the car last night.
spotted Haysey's white 32 on Dangerous last night.
Also spotted TUFGTR.
p.s. Don't think I can watch any more of the show. The lead actor and his "crew" really annoy me. lol
yeah im famous!!!!
The lead actor is a bit of a nobody, but brooke is nice.. that lebbo guy is from hartbrake high and the chick isnt too bad... vico the asian dude i was chatting to for ages and hes a top bloke too......
yeah im famous!!!!
Is that show any good? I keep hearing ads on the radio but I dont have foxtel to watch it. Brookes a hottie :yes:
Blue lancer infront of you as we went over the train tracks
Was this in the morning or the arvo? Cause i remember a blue lancer this arvo "racing" a camry which was being a total dick (the camry) and the blue lancer was lowered with two guys in it?
Or if it was this morning didn't notice one bit of a dime a dozen around Epppiiiinng.
yeah its not bad, its getting pretty good reviews an stuff, some people dont really like it but each to their own... I conned mum into getting fox so we could watch it so thats a bonus!
Brooke is farken hot and very nice too, was chatting to her for ages, very down to earth and easy to talk to!
yep that was me and craved.. and sif racing the camry
that f**king camary driver was a moron.. almost took himself out over a gutter then cut a person off cos he drifted into their lane..
One of them may be me Black 32 CF bonnet.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
