Yeah Mooney Mooney is the big dipper isn't it? The last hill before the gosford turn off, you were in the fast lane naturally and had the window down with your trademark sunnys on.
It would have been around 5:45 or something like that about 7mins before i sent sms as it didn't send and it kept retrying until it worked.
big dippers the the hill at mt colah
Nah big dipper is when heading to Sydney and coming up to the end of the F3 and you go down the big hill!
btw love the new signature..... bwahahahaha
Ahh ok thanks Mitch/Anna... now i know...
And had to make use of at least some of the photos i took!
oh ok, if i see you ill beep!
my mates live all over the area so im always around. i get my hair cut at rogers across the rd from chicken wizard too.
Haha no worries. i'll probably be like who the f**k is beeping.
spotted ethan at castle hill and a r33 at meadowbank warf
haha, i only relised it was you when my friend was like, do you know that guy, hes waving lol..
car is sounding quite nice with all the good bits in it now, and looks good too, being all black, and not black with a white skirt :no:
spotted a very nice midnight purple GTR that looked like it was loved... plates GTR 206 i think...
i flashed em, but i think i was mesmorised by its sexiness for too long and was too late...
car is sounding quite nice with all the good bits in it now, and looks good too, being all black, and not black with a white skirt :)
haha cheers dude.. ur cars sounding good as well...
stock kit is back on at the moment while we sort out some prepping issues with the vertex kit :)
as with Mikey's post :) cept for coasties
Also spotted a white 33GTST on M7 - had a chat while driving :)
and spotted scoobs all crossed up trying to chase me at OP :ninja: hahaha
Saw three Skylines on Johnson Avenue in Seven Hills about 3.30-4.00pm today.
One was a two-tone silver/gunmetal R33 GTS25t coupe, one was a black R32 GTSt, and the last was a gunmetal R32 GT-R with Nismo wheels...
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
