spotted an R33 S2 GTS-t silver i think on taren point rd sans souci this morning... had an SAU sticker on his back windscreen.
i dont wave to many ppl.....either day dreaming/dont get a chance/dont want to get snobbed if i think i will....lol...
i wave at everyone
get a response from half..
usually if they look fully hektik.. they dont respond..
yeah seems to be the case with me aswell
ill start waving again and see how it goes
Hey guys ive had my white R33 for 3 weeks now. If someone spots me between fairfield and chatswood area make sure you beep and hang out the window and wave and shit - hehe :sleep::)
You'll know its me because i have an italian flag on the review mirror.
Edited by Skyline_95GTS
ok.. let's see..
white R33
between Fairfield and Chatswood
Italian flag
can you be a liiiiiiiiiitle bit more specific???
Haha - not really its pretty stock so theres nothing else that i can add so you know 100% its me... it only has 4.5'' exhaust and a BOV so you'll hear it coming... im in those area in the mornings and afternoons (travelling to work and back) hehe.
Oh i have a big JapStyles sticker on the back windsheild.
spottes silver r33 series 2 with fmic jus near oatly train station he highbeemed me and i waved but i dunno if he saw me. number plate was im pretty sure kr-200 i use to see him nearly everymorning wen i had to catch the bus to skool
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
