saw a white series 1 R33 with yellow plates AJ 67 GW or some other random shit... i flashed them, and i got a flash back AND a wave out of the passenger side!!! thats the first reply ive ever gotten :ninja:
YAY!!! I've been spotted :pirate: saw you too mate my wife was driving, nice looking car.
is ur car white with the transformer sticker on the left rear quarter. if so i spotted u the other week out the front of salty roaster
Yeah mate that was my wife she had my car and she works there.
Spotted a gun metal grey R33 all the way back from Homebush until Beverley Hills... And a quick chat at the traffic lights, anyone on here?
Edited by Abo Bob
SAU doesn't condone street racing.
spotted a maroon r32 gtr on great western highway about 8.30pm
plates were aks-*** something
Might have been me! ANS ###. Was with a soarer.
Didn't see ya.
But spotted a light blue 32GTS-T, kit with open wastegate, sounded cool!
YAY!!! I've been spotted :mellow: saw you too mate my wife was driving, nice looking car.
hehehe awesome! loved the wave from the passenger side :laugh:
and thanks, i need to repair the front bar though, one of my mates drove it into a concrete parking block when it was 8 days old...
spotted a MNPII R33 GTR plates GTR026 this morning... its a nice care, i would like ot see more of it, but hes a f**king snubber... ive seen him like 3 times, flashed and waved and got nothing!!!
not to mention i was doing 40 behind some asian dude on the comenarra speedway... f**king annoying...
hmm spotted a white R33 GTS-t or GTS (can't tell the difference for R33s) ASD 74W (I think) on the way home.. but had to get home quick so I had to speed of.. would have love to keep driving alongside u... did a mutual wave at the same time.. was pretty fun..
on another note.. spotted a pretty cool looking asian chick driving a black supra SUP 24A yesterday.. was in my little loan mazda 121 car.. so didn't wave.. keep a look out for her.. cute chick...
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
