haha.. sam, you started it!
I remember leaving James one night.. putting my car in reverse, turning around to look and seeing You, Wilch, Mona, James and someone else all rubbing my cars ass! LOL
so who put the skylines aust card on my front window then? parked next to coles lindfield (grey blue cefiro)
you could ask the same question in the hornsby thread, chances are the person may be from round there...it wasn't me, i'm at work :D
haha
trend setter bitches..
i drive a black gtr always hanging around randwick coz i go to unsw. what car you drive?
oohh cool.... someone who goes to UNSW, i go there aswell. wat year are u in? and what degree are u doing?
DIF has a black r32 gts-t
i got a white r32 gts-t sometimes drive to uni depends on how i feel. so would that have been u i spotted the other day on wednesday near BP?
yeh i think i went in there to get some ciggies or something cant remember. i am just always around the area like randwick coles and parking nearby to go to uni and anzac parade for dinner.
im in final year studying law so hanging around lower campus. how about you?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
