No-one spots me either, i see heaps of Skylines on the way to work and back and post it but they must not be part of SAU forum or they just too lazy!!!! =( havent been spotted once in the 2months ive owned the car!!
I've never been spotted even with my custom plates and parking my car in the same obvious place in a busy location 5 days a week....
spotted SAM916 in Artamon, near the tittie bar which I was heading to :domokun:
haha saw you to mate, also saw a massivly stretched hummer just after i turned the corner. I know the place your were going to! (A guy at work organised a free tour there because we 'worked in the area and wanted to become familiar with the local businesses' :nyaanyaa:
Spotted a candy hot pink R33 in Bankstown the other day with a guy driving it (guess he likes pink)
Anyone on here?
there was a guy that came to the coast a few weeks ago, could've been him (did he have 20inch chromies?), tinks gave him a card but haven't seen him on the forums...
haha saw you to mate, also saw a massivly stretched hummer just after i turned the corner. I know the place your were going to! (A guy at work organised a free tour there because we 'worked in the area and wanted to become familiar with the local businesses' :D
Man that Hummer nuts!!!
theres a few over in Hawaii but first Ive seen here - and the driver I think was a former body guard for a celeb....farkin massssssssive!
Suprised you reconsied me! :rolleyes:
What was the number plate?
I don't remember, I only remember him cutting us off and the girl who was driving the car I was in yelling "FAG" out the window really loudly :D
Then it took off, dunno about the chromies, but looked to be in poor condition, paintwork-wise
The only pink 33 I know of is in brighton.. and hes one of the guys on here's cousin..
Spotted a couple of r33's at livo KK's tonight... one was a charcoal series 1 with whitewalls and chromies, the other was a silver series 2, NVD-33R.
Also spotted a bright orange r33 approaching the elizabeth drive and hume highway intersection at about 11:40pm. Looked pretty nice...
Hi, always see a Yellow R34 in Glebe around broadway aswell? Do you know a Jerry with a silver R34 kinda looks like the one from Fast Furious but its a GTT, well he knows you and he knows me ( Grey Gts-T R32).
i saw "R33-SKY" in kellyville yesterday. Also saw a black r32 gtst at norwest same with a dark colour r33. can't remember the plates but i parked my gtst right in the middle. So if u guys r on here wassup
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
