Is your plate EXH45T? If so you probably got no idea what series 2 looks like :closedeyes:
It is! So you are on SAU! Sorry, i thought yours was a series 1 because your rear "skyline" garnish is clear(?). Maybe my eyes were playing tricks with me :P
Spotted around 4:40pm a silver R34 GTR at hookems corner in asquith, nice car!
Then shortly after a silver R34(not sure if it was GTR) at Mt Colah lights, had something painted on the mesh of the front bar, nice looking car as well. I was stealthed in a ford festiva LOL
no, the OTHER mona!
lol
on lane cove road.. you were just pulling into the right lane to turn right.. and pulled up next to me 2 lanes over but i had a green light so I just beeped like a lunatic!
lol.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
