lol :P
I saw you parked behind me and was gonna post here as it looks like mass-iv's old ride...
oh, and hi lanky... ;)
Yeah its mass iv's old toy, i don't understand how you get such good parking all the time, every time i go to uni you have a good spot and i have to be a cheap skate and move my car every 3 hours at broadway lol
have to do it..
SPOTTED LIKE OVER 100 SKYLINES TODAY AT GRANVILLE OMG WHAT WAS HAPPENING THERE LIKE WOW
Heard they were up to no good and the cops blocked the only exit to defect em all!!
Yeah i happened to drive past the show n shine and went down to have a look.. some very very nice cars there.... the candy red r32 Gtr G U UP Dat Was aswesome.. I was really really really inlove with the Blue r34 Tommy Kiara Gtr .. that Car was Shmick...
And you probably would have seen Chubbs in the grandpa spec 31 behind me. Must have been a bit later than that though. That's also about where the lancer tried to take me out. Do you drive a lancer in your spare time... :thumbsup:
nah i was in my 33 with a smashed window that night.
also spotted 1 or 2 skylines at granville park today on the grass. what was going on?
yep, that's Nicolas, aka NicsR33
w00t w00t spotted!!! *does a dance* except i honestly can't remember driving last tuesday :thumbsup: we1rd???
spotted alot of skyliners today at the show-n-shine!!! that orange FTO had the best paint / rims combination ive never seen!
i saw you pull into the show, then i didn't actually see you at the show :domokun:
MRGTR911: 2GUUP is a "Get That Sideways Toy" with an RB30 bottom end, and i 'think' an RB26 top... very VERY nice ;) i lurve it :)
do you REALLY think it's a sideways toy?
only reason it got towed is cause it wasnt running at the time
when it was running (couple months ago) i used to drive it 3 or 4 times a week
the boys and i cruised the city every weekend
its no trailer queen
i even drove it to gold coast autosalon last year 20s an all
i didnt have to bring it to the show
but i thought it would be nice to show something different to the usual skyline
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
