ok, i know i'm being a bit of a post whore but there is this sexy silver 33 GTR that i've seen around Wetherill park (where i work) so many times now and i saw him again at the servo today. the car is always immaculate, and fair enough, the owner is quite a bit older than me, but for that car i'd have a go!!! hehehehe, the number plate is...wait for it...GTR33 (shocker!!), anyone know him? :dry:
ok, i know i'm being a bit of a post whore but there is this sexy silver 33 GTR that i've seen around Wetherill park (where i work) so many times now and i saw him again at the servo today. the car is always immaculate, and fair enough, the owner is quite a bit older than me, but for that car i'd have a go!!! hehehehe, the number plate is...wait for it...GTR33 (shocker!!), anyone know him? :P
:dry:
spotted BBJ-17R(white R34) and SECRT gold R33 GTR on windsor rd yesterday around 4. That SECRT GTR is HOT!
I feel horrible for writing this now. I just read a post that the guy that owned SECRT was murdered. RIP
Edited by NG0387
Spotted Wilchs car waiting for some TLC..... and its been in the same spot all day thumbsup.gif
happy now chris? :domokun:
Yay! but :blush: they should be working on her, not sitting in the sun all day. :wacko:
But yay re: spot! lol, the first time my car's been spotted in years and I'm no where near it.
Spotted a white 34 GTt - AYB*** pac hwy this morning near Chatswood
Was trying to give you a wave, I was in the 31....
I need a MASSVIE SAU sticker on the 31 so people dont get scared :) hahah
I think they would get scared anyway....
:):):O
spotted 2 white gts-ts one in randwick junction the other one near centennial park... then i saw them both together behind each other near the moore park supa centa.... hours later! weird!!!!!!!!
Saw the MAAARRRRSSSSSSSS mobile avoiding the traffic near the airport thisavo too!
Hey mars! *waves pinky in air*
lol
spotted a white r33 as I turned off windsor road onto a side st and the turned from the side st onto windsor rd last night around 8pm in Baulkham Hills, then 10 minutes later spotted them turning onto old northern rd from a side st as I turned into the side st from Old Northern rd..
Spotted a silver 4 door r33 with a chick driving two days in a row, both times I just got to the top of my driveway as they drove past around 9am
lol!!! sometimes stalking can be fun :w00t:
you crazy stalker!!!
I thought it was caines car.. but didnt look like caine.. and I couldt see you thru my tint (true story) so took me a bit to realise it was you lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
