spotted burnsie last night at wsid....few lines, mainly 32's and 33's....i also spotted the hot chick driving yb50ft....car was pretty hot too....ran a 14.2 with shocking 2.7 60ft....
yeah but she did have a high mph good for low 13's but she left early with problems
u sure it was silver.....i was on there but i got a white s2 with AYB...
Im not colour blind lol, Yeh was definately silver with nismo lower lip and maybe 17'' rims i was walking to get some food for morning tea maybe 9.30-10.00am?
Sorry bud....wasnt questioning your ability to distinguish colours....just thought maybe it was at a distance...
Hey its cool didnt think you were questioning my ability to judge colours he he :thumbsup: ... ill prob see you some time i work on vic rd
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
