spotted a black R33 in a head on accident with a 4x4 around 7ish tonight just before captains cook bridge, south bound before the bend.
I drove past this too but at 6ish.. the 4x4 looked like a CRV and it was UPSIDE DOWN!!! on its ROOF :stupid:
hope everyone was alright.
spotted a white r33 on pennant hills road last night.......
spotted a silver r34 with Grim Performance sticker down the side
The silver R34 is a guy named Brendan(brenno34) on here I think, lives near me in Mt Colah, damn nice car
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
