I think i spotted prime cordial (Jon) coming out of thornleigh maccas this morning.....gave it a squeeze....it was me crossing the road when u took off....
Oh that was you? Heya! :P
LOL, that guy/chick lives down the road from me, always parked outside, nice lookin ride wit red rims and no spoiler rite ?
Was very nice although i did notice a bit of damage to the stealth wing on the back. Don't know how you could manage that?
Hey Adrian,
I live in Hurstville too, welcome to the forum! >_<
I drive a Series 1.5 R33, plates SL33KY, no more p plates either!! :glare:
Cool! I was hoping for a few people around my immediate area. Looked like most of the people were out west or something!
I'll keep an eye out for you. I got a white s2 r33. Complete stocker atm but should have some engine mods and rims by the end of the month
Spotted Slim this arvo on epping rd
also blue 34 gtr "POSSM" near towers, a black 34 gtr on sunnyholt, infront of it was a white 31
ah so that was you!
Also spotted LUKEY 9 I think the plates were.. Blue R33 in Baulko
Saw a Black R33 today parked at North Sydney TAFE. Has Nismo stickers here and there, as well as a Series 2 looking wing
If you took a walk around to the back of the car park (near the spray painter area) you would have seen my Skyline :(
Im from very close to there aswel :(
Look out for a black JZA80 supra with dark tints and super low side skirts
POSSM is a nice looking car. They had the 98 GTR V-Spec before.
Too bad it's mummy's car eh? That's the "chic" behind the wheel.
yeah im pretty sure was some mid aged woman drives it, sounded so awesome though
Nope, ive got a black supra and a white GTR - sorry, no black skylines :)
Bahh ... I need to pay more attention to what I'm typing late at night :(
I meant supra where i wrote skyline haha I think I should be heading to bed
Haha yeah thats cool
Nah not near Lugarno, but if you see a black supra driver waving dont be suprised :)
Spotted marsss yesterday on cnr of hume hwy and stacey st near bankstown/greenacre
damn... my cover is blown...
(note to self.... be fooly sick elsewhere)
around that time i spotted a 4 door white 34 with a very nice looking chicks in it uleh
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
