saw mas last nite, and his mental R34 GTR.....went for a quick spin....that thing has enough power the change the speed of the earths rotation!! :P thanx for the ride mate :P
haha yeh she goes alright ay....
spotted QATAR in the city today.. black r33... nice ride
Smee Again! ( I think anyway, last night around 8ish? )
Taking the scenic route to my girlfriends.
Ahh that was you? Cool! :dry:
Maybe we can hae a white R33 S2 touch up paint party :thanks:
IN!
hmm.. spotted xx34xx cruising around...
NOT!!!!!!!!!!!!!!!!!!!!
Hurry up and show me the car you meany!
You really are missing out, it's fatty fat. Meanwhile i may/may not be making a few copies of the tommy kaira for spares or if anyone out there actually wants one :dry:
