who the f*k is Jason?
JET-32R was owned and built by a guy named Lucas
Yes it was :P
JETR32 on here (Jason) did not sell his car i believe... or did he?
Also spotted Anna this morn on the way to work... NIGHT RIDER! :D (during the day time)
Also spotted Anna this morn on the way to work... NIGHT RIDER! :P (during the day time)
:D ... for the last time... its not Kit... its not night rider... its the Black Bish No 2!!!
btw was half asleep and didn't see you this morning... assuming it was in the same spot as usual???
spotted wink parked yesterday at manly and also a silver r33 series 2 parked at manly aswell number plate ***33r
both nice looking cars
Yay. Thanks!
Finding street parking in Manly beach on a sunny Sunday afternoon is bloody hard. So lucky I got that spot - and the Skyline wouldn't have fit in there either! :D
Spotted in Chatswood yesterday "DR SKY" white R34 coupe.
LOL guy obviously abused the shit out of it because that car has been going for the past 2-3 years without even the slightest of issues
i used to drive it all the time and it was great
I'm always seeing GTR-97V around Dural in the arvo's. It's a nice, clean white one. Not sure of the model tho..
And the other day spotted a nice pearl purple 'Line out at Bunnings Dural, it looked mean
Obviously :laugh:
I mean everybody knows that it takes an entire 3 days to kill the big end bearings on an RB26.
Your mate got the better deal, mine now has to try to find the money for a rebuild.
I havent actually had a chance to trash it yet wanted new tyres and brakes before I did that
just driving home casually last night and it starts dropping oil pressure then it started the big end knock :laugh:
LMAO what a joke
funny how people who i know saw you thrashing the arse out of it
but it conveniently dropped oil pressure while "casually" driving home
really? I was just casually driving it home at the time, but regardless whats done is done, I bought the car now its my problem
and my idea of thrashing is more than just a squirt every now and then which is all ive had a chance to do...
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
