Hey mate thats me... thanks...
yeh wudnt have noticed you.. iv been driving my car around lately hehehe i cant help it, its still new to me :)
dont be shy to say hi next time.
I will for sure. If you see someone someone waving madly from a red 1986 Corolla or a Silver R33 S2 Sedan, that will most likely be me.
spotted sex on wheels today.... XX34XX...
:drool:
Totally sex -MASS-... totally sex!
haha you spun me out wen u rang me... i was like huh u must be standing in the car park lol... next time ill keep her in the sun so u can drool even more :)
haha will do, ill be sure to keep the camera on hand and take a photo of u waving like a mad man, so i can stick it on here lol.
Spotted moanie on morrison rd gladesville/tennyson/putney/ryde at the western cresent roundabout at 6pm. I was in my red corolla.
oh woo!! not sure where that is, but sounds like my route home :D:)
haha you spun me out wen u rang me... i was like huh u must be standing in the car park lol... next time ill keep her in the sun so u can drool even more :P
hehehee... i honed right in on it! and yes please... some sun next time would be nice! :D
oh woops, and i spotted -MONA's- and caine's car in my gym car park..
:giggle:
OMGWTFBBQ who is sheng? I spotted DJ_Albert on windsor rd :) actually it was skyline day that day there was a white 33 next to you from memory
hahaa
Dj Albert was my old username lol, it was lame and more lameness so i changed it LOL
but sheng its me :D but im still albert, call me wateves GET IT :P
welllll the white one next to me was a tool, had like 10 woofer run out of 1 one channel amp, and the dude was looking through a crookerd rearvison mirror
...mm must be the subs
Spotted a big white Nissan Patrol 4WD flashing and waving at me just off castle hill road about 2mins ago.
I kinda nodded. Wasn't sure what to do actually. Who was it?
:) if you're on here.
just spotted a white r34 2door,had a big aftermarket front bar. looked hot
im pretty sure it was a blonde chick driving,,,well i hope....cause i was pervin.LoL
@ the set of lights out front of woolworths on Greystanes rd heading towards the great western.
Spotted a GT350 Skyline V35 (blue) with SAU stickers in ryde to homebush then you turned onto m4.. Plates ???-50V or somthing.
Have to say car sounds great, was in a Accent drueling over your ride
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
