Spotted a p plater in a silver R34 cutting me off without indicating then swerving into an exit lane (also without indicating) going towards Maitland. Not a good way to make friends.
All on my way to work this morning,
silver Stagea in chatswood, northbound
silver R33 'Sqiish' in Ultimo wth sau stickers on the windows
and gunmetal series 1 R33 next to my work wit a disability label thingo;)
spotted jon yesterday arvo and i know u spotted me hahah
Haha yep, definitely spotted ya! Arm out the window :D
Spotted a Silver R32 GTR on Castle Hill Rd on Saturday near the middle of the day... He flashed me but my g/f was driving so I couldnt flash back (I asked her to flash but she said I needed to get a few drinks into her first!) :O
All around 6:45pm, waved at a guy in a gunmetal R32 GTR on Pac Hwy between Mt Kuringai and Berowra, then another gunmetal R32 waiting to turn over the bridge at the lights in Mt Colah and spotted a black 200ZR in the Mt Colah Maccas drive thru (Anna?) :D
it was me @ mt colah lights
i waved u waved
what r u doing tomorrow nite?
come out for a meet @ P6,
sounds huge
Spotted a few lines today.
-Silver R33 GTST with exhaust, HKS power sticker on rear bumper, p plates- spotted on Narellan Road, Campbelltown. I was next to you as we turned right at the lights.
-White R32 GTST, being followed by another silver R33 GTST- spotted near Picton
I spot many a skylines parked in my street of an arvo after work... dunno why...
If you go to North Shore gym, or work in Bridge st Pymble... HAI! :P
AQD38T - grey 33
a grey 32 all the time
white 33 GTR INHEVN or something... might have plates mixed up...
:P
squish is Smasha.
I iz famouzz
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
