Must of been some other nugget cos my plates are AR-36-UA now lol. RTA has to reissue me with osaka cos it ran outa rego for over 3 months, should be ready in a week or 2.
naaaaaaah was definitely your nugget i didnt see close enough to read the plates :rofl:
naaaaaaah was definitely your nugget i didnt see close enough to read the plates :)
U dumb ass i was playin guitar hero3 at a mates house till 12am then parra for coffee. I didn't even go live that whole weekend.
Ur more likely to spot me out ur way. On that note how safe is my car in st clair?
you got clones then!
guitar hero 3 is a pretty homo thing to be doin
st clair is.. ok... depends what street.. it's safer than alot of suburbs thats for sure but still i prefer parking off the street
i've always parked my car on the lawn behind the hedge and haven't had issues
Spotted on sherwood rd merrylands, 3 sexy blue cars all together looked like they were headed for a cruise. R34 GTR Followed by a sexy ass R33 GTR with sexy dish! also followed by a sexy 03 WRX with leather & sexy wheels very nice...
and you know this because..........
because i'm a perfectly straight person therefore have a good idea of what is normal activity for a straight person like me. guitar hero does not fit this description unless you're 10.
spotted a black (or dark colour)r32 gtst in hornsby at bout 6.00pm tonight plates ahtxxx cant remember the numbers.
was just near the station pulling away from the traffic lights and testing the rev limiter at the same time!! sounded sweet!!!
Edited by Mini R33 Skyline
Spotted a White V35 Sedan maybe pearlescent, lowered, dark tint, nice body kit no idea which brand, and couldn't catch the number stopped in traffic outside epping station heading towards pennant hills rd on beecroft rd at like 6'ish i think it was.. i was on the side walk waiting for dinner.
got i waved from black r34GTT with green ps on anzac parade early this morning, while i was walking lol
and spotted a white R34GTT with plate "BAU..." on oxford st and another white R34GTT on geoge st
Had a black R32 GTR done up JDM style follow me down carlingford rd onto beecroft rd where i turned into epping. Didn't catch number plate. Had a big crucifix hanging from the revision mirror.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
