spotted red r32 'WTF32R' in woolies carpark neutral bay 7pm tonight. wasn't driving, was walking to chooka's to get some devil wings. damn i miss my car, i really wish CRD would hurry the fcuk up and fix my missfire already :)
spotted a red r33 S1 on king georges rd.. haha car was spitting out some really insane flames... if ur on here good stuff i was loving it... i was the dude driving the blue astra convertible (relax its the girlfriends car)
spotted maroon 32 gtst on parra rd this evening around 11:30ish, turned off at concord rd
also a silver gtst sedan that gave chase to him before he turned off lol
dont think either were sau'ers?!
Spotted me swapping rims with Dr D00f for autosalon, these stockies are lol Steve :( No traction on boost
Oh and spotted COG51E, white R32 GTR in Asquith
pffft... you love it :)
Thanks again mate :D
saw doof snoozin in his car at autosalon
saw umm jet-32t blue 32r? driving in olympic park farrkn sounded toughhhh
I was sleepy, and those seats are comfy :D
Spotted and waved to a guy in a purple R33 sedan near victoria rd in Chatswood and got a :P back! Nice car :ermm:
Also spotted a white R34 with big GT wing on Warringah rd heading to Chatswood..
Edited by phillb
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
