I actually went on site for once today and at Baulkham Hills I saw...
Deep Blue R31 sedan AR-51-GP
White R33 GTS-t (I think) with a GT-R wing WGH-051
Then on the way home from work at around 5:10 I saw a silver R33 GTS-t on Mona Vale Rd, somewhere near the Bahai Temple.... I think...
Spotted a white R33 GTR with blue plates "GZILLA" or something like that at North Ryde today turning into Optus.
Hey that was me. I saw a Burgundy R33 GTR driving down Lane Cove Rd this morning too. A few GTR's in N-Ryde.
Spotted a dark grey R33 Gtst in hornsby this arvo , was going past shell and then straight down next to the school , had a sau sticker on the front. I waved but dont think he saw me!
If it's black, manual and has all the gauges - then I might be interested :ermm:
I gave up trying to find a four door like that...
Umm.. Silver... Tip-tronic and has all the stock gauges lol.. When i got mine no manuals were available but then 3 months later nothing but manuals lol.
That's probably Evil Weevil
I spotted a few around 6 till 7pm on the Pacific Highway all between Turramurra and Chatswood, a Gun metal grey R33 4door, a black R32 and a silver R33 series 2, waved to all 3 and nothing back :P
Spotted a silver R34 4 door in waitara on the pacific hwy with a space saver on the left rear... driving nice and slowly!
That was my car... I was up the coast working so had to borrow folks car but .... cough... mum.. cough graciously took the car to the tyre place to get it fixed.
At Erina Fair massive set of keys was "stuck" into my tyre... managed not to damage it enough to get it plugged for the moment.
You live up the coast you should come to our weekly thursday night meets.. not that i'm a local live in epping but work up the coast so i pop down after work.
See the "Weekly Thursday Night" cruise thread for details.
Yea havent been out much latley..
I will be out.. im showing bryce and ian the way down... ill bring my car out now!will be good to meet ppl
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
