Don't know the purple one, but think I remember reading about it being spotted around, bound to be someone on here. No good about that spitting mate.. often hear drunks up & down the street at night so probably that. Will of course keep an eye on your beast, always looking out for 'lines!!
Will say hello if I see you there sometime.. good luck with the mods.
Gareth.
i know the purple one. his not on here juz keeps to him self really
if its got ugly chrome wheels then yes thats mine...lol
hasn't been on the road for about a month now... what do you drive?
oh ok lol
midnight purple GTT :P
spotted my car making 242.5rwkw
Also spotted a Blue R34 GTR in Bicentennial Park tonight in Homebush
on friday at norwest shell spotted a black (i think) R34 GTR - HAWT!!!
and yesterday whilst drivin old windsor/winston hills/rouse hill area spotted a red s14 with black bonnet on old windsor, red s15 (plates MYS-15J) old windsor.
and at rouse hill spotted a white FC RX-7, and a hawt candy red s14a with chrome wheels at rouse hill shops...
edit: also spotted black WRX - 4DHTRZ changing a tyre on old windsor road. would've stopped to help but i wasn't driving and there was a few ppl there by the looks of it..
and also spotted one of the guys from UAS in his 180..nice ride
Edited by Black Widow
spotted a sex 32GTR in west ryde today.... black with plates AUB***, also got a nod and compliment from a guy in a 32gtst just before the GTR. Thanks mate, was me in the 34 GTR....
what wheels do you have mass? cos i don't think it had the TE-37s (is that whats in ur pics?) Or were you talking to Sheng?
spotted an old skyline owner at BP Artarmon. Wasnt from here I dont think, but had a good chat about cars and bikes while filling up with fuel, good bloke!
Gotta like meeting like minded enthusiasts even though you've never met, but still have a good chat!
And spotted Ando while I was waiting for road side assistance :yes: lol
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
