Spotted a black 32 gtst ( AJ 59 __ ) on the M5 city bound at around 10:30pm doing between 95-105kph in the 110 zone, staying in the right lane the whole time pi$$ing everyone off. Nice work champ :rofl:
Spotted anna spanna (msnismo) in the 200ZR in turramurra just before st ives round 11 30pm :D
I spotted her in Hornsby shortly before that...
Shoulda come over dude, I had a crazy night! :D
Driving home, decided to see what the terrourists were up to in town (Kiama).
Spotted a black 34 parked in the main drag and a little further down the street, another R34, this time a nice looking silver four door with a boot lip.
Love the four doors... should be more of 'em I say :D
spotted firstly in the entrance on Saturday at like 2pm in the main st a silver 4 door non turbo 34 with nice side kirts, and think its the carmate 4dr gtr rear bar very niiicceee and the fully hetkik wing. Number plates MAROOF
Then driving home last night getting on the f3 at hawkesbury bridge when i turned on it was next to me again.
On saturday.. spotted a gray 2 door skyline at asquith(spl) BP across from the train station. Dont ask me what model cos i was on the train.
On sunday.. spotted a white R33 GTS on Raymond Terrace Rd on ou way to Berro.
were you around there saturday morning?
yeah I live 30 seconds down the road.. and I was driving a fair bit on the weekend..
did you get a good look at the car..?
I've got LED taillights, no wing, 20% tint, vertex kit, bronze TE37's..
