Spotted a silver 33 not sure if it was a GTR it had too many after market body parts on it.. gave him a wave and I got a funny look back. This was this morning over the Gladesville bridge (Victoria rd) at about 8.20am
Oh I also saw a really hot Dark blue 31 GTS with a big fat FMIC on Centennial Ave Lane Cove this morning at about 8.35
Spotted in Chatswood a white R33, asian chap driving I waved but nothing back :P
And spotted Mitch(Mr Moo) following me home :P
did see you at kfc, then you cought up, but the work van just couldn't keep up :rofl:
hahaha! I thought it was Haysey!
Sly work with the camera when I was sitting at Mangrove waiting on the C&I Cardigan Club to catch up. :cool:
Who was that guy that did his front end in just up from the pub?
hahahahahaha blue flame drive by twice lolz
one of the guys had a bit of a skid, nothing too major, he could move it and what not.. just a bummer it happened on the cruise... coulda been worse!
Spotted TJ...........'s old GTR :D
so that means I spotted Matt! Hai!!!
Sorry my head was elsewhere and I was completely not thinking (heading to the hospital) - hence looking at you like "who the f**k is that?"
I'll be more social next time :D
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
