lol and I thought the race car was low key. was off to hills to get it tuned.
that traffic was shithouse I could not do that every night. especially not with a race clutch, straight thru zorst, race brake pads (ie no braking when cold), no radio, no demister in the rain.
Were you in the Z? I didn't notice it :P
nah the 33..... i was crawling through the etag thing to get onto the M2 and caught the yellow beast out the corner of my eye...
Yeah im usually going in the opposite direction but tonight was long weekend crazy traffic... never normally that bad!!
Spotted white 33 gtst on luxford rd mt druitt round 930 this morning.
Spotted myself driving after 9 months worth of suspensions finally came to an end today :P , must remember to be careful coming off suspension in double demerit times.
Spotted ROB 32T I think it was in seven hills today.. awwwwwwwwwwwwwesome looking car, I think it was a bit laggy though or it was just double demerits lol
spotted an older dude in a silver R32 GTR in seven hills around 5pm too.. then another one on seven hills road parked..
spotted a few SAU'ers at the northern last night .... Steveo, Ando, Adam, Carly, Corinne, Dave, Georgie, Nick, Smoky.... ummmz did I forget anyone????
Didn't forget me....as I wasnt there :( d'oh
Spotted my car in the garage when it should be ON the road and racing this weekend :P
Didn't forget me....as I wasnt there :) d'oh
Spotted my car in the garage when it should be ON the road and racing this weekend :)
Awwwww tried calling you to make you feel included... :P
I think I was a bad influence on Georgie.... she was "k im going home" and I went "just one more drink" :)
several times this sequence occured.... :(:)
Spotted coppers following me home ... again, :(
was on the driveway waiting 4 the garage door to open to sufficient height so I can get in
wankers stopped on the road in front of me driveway and shone some bloody torch at me car
can I make a complaint for stalking?
how was wakie yesterday? sounds like it is very wet for the state supersprint today
Was a fantastic day - sunny and cool, about 21. It was my first time out at Wakie and first time in the GTR all out on the track. I think it would have been better if my front transfer case was actually working as I was oversteer city everywhere.
I managed consistent 1:20's with a 1:17, 1:18, 1:19 while chasing down the Evo and Breakmaster. That was on my street tyres that are just regular 'ol Toyo Transas. Next time I'll bring out the slicks.
Now my pads are a bit glazed so have to tear 'em down to scuff them up. Better get some track pads too.
Great day!
(although I had to vacuum out the car from all the grass and dust, I went off about 5 times :blush: my bad!)
Edited by Pezhead
OH MY GOD! OH MY GOD! I GOT SPOTTED :PBJ:
Thanks man :blush: wanna buy it :blush:
I think it was a bit of both (lag and double demerits)
I saw the plates and figured it was you slim, nice car dude.
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
